Author Topic: 1.8 se spluttering running rough once warm  (Read 1422 times)
Offline Gal
« on: 24 February 2011, 21:26 »
Hi
I thought I had fixed this once I had put on a new coil plus cleaned out the throttle housing with carb cleaner. I have changed the plugs, dizzy and rotor arm. Awaiting relay 167 in the post. Also changed temp sender
Now I know the car gets up to temp, but blows out mildly warm air out the heaters. I'm guessing thermostat not working, but would this make it run/sound like on 3 cylinders once driven for a couple of miles?
It may be me but I'm sure its worse when damp and raining
I checked coil again for sparks by spraying it but seems ok
Why oh why did I get another mk3 when I prefer mk2's?
Offline Gal
Re: 1.8 se spluttering running rough once warm
« Reply #1 on: 25 February 2011, 11:36 »
Well the plugs were shagged. Replaced them. This morning was damp and it juddered a little driving while cold. More so once warm and accelerating. Still waiting on fuel relay. Anything else I should check?
Thanks
Offline javalin
« Reply #2 on: 25 February 2011, 11:46 »
yeah - change the thermostat.  Engine coolant temp is a key input to the ECU (coolant temp sensor) for fuel management.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #3 on: 25 February 2011, 12:11 »
As above the thermostat will not be helping. :smiley:
Offline Gal
« Reply #4 on: 25 February 2011, 13:55 »
How easy and how long will it take. Finish work soon and gotta be done straight away then
« Last Edit: 26 February 2011, 09:35 by Gal »
Offline Gal
« Reply #5 on: 26 February 2011, 09:37 »
Up for weekend. Anyone know of links or got a good photo how to for taking the power steering pump off to get to the thermostat please?
Thanks
Offline javalin
« Reply #6 on: 28 February 2011, 09:13 »
just unbolt it - you don't need to disconnect it.
have a read : http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/coolingmaint/index.htm
Offline Gal
« Reply #7 on: 01 March 2011, 17:29 »
Thanks that helped a bit. Managed to get under there but wind and darkness got in the way. I still cant suss out which are which bolts are to undo it though.
Car beginning to pee me off. Once this done I am selling it!
I do mean that too. Going back to retro VW so if anyone wants a 1.8SE then buzz me
