Author Topic: Clutch or gearbox problem any ideas  (Read 869 times)
Offline carpetviper
« on: 24 February 2011, 18:53 »
2 weeks ago I had a new clutch fitted and all was good untill the pedal stuck to the floor and wouldnt return so my garage fitted a new input shaft and nearing.
now when i press the clutch while in gear I hear a whirring scraping noise but only if a gear is selected and only when the clutch is pressed.
When driving everything sounds normal till the clutch is pressed to change gear.
Does anyone know what this could be ?
Re: Clutch or gearbox problem any ideas
« Reply #1 on: 24 February 2011, 21:03 »
Sounds like a knackered release bearing
Offline carpetviper
« Reply #2 on: 25 February 2011, 20:53 »
Cheers the bearing was supposed to have been changed but Im gonna have it checked out
Offline redrabbit1991
« Reply #3 on: 25 February 2011, 21:08 »
when the clutch sticks to the foor its normally because they havent bled the system properly or not at all as for the scraping it does sound like a relsease beraring mate
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 25 February 2011, 21:43 »
only on the 16v that's true but the 8v uses a cable and the clutch arm (ratchet) cracks making the pedal fall!
which model is it? (again the 8v clutch kit comes as 2 piece (without the bearing) but as this is on the gearbox side there easy to fix (subject to space!)
