Author Topic: Raising coilovers, harsher ride?  (Read 1154 times)
Offline Bellend
« on: 23 February 2011, 23:29 »
Raising the car up for the paremts but notice that the spring starts compressing quite a bit now, helper springs compressed. Thinking about it, is raising it to the highest point going to make the springs rebound less and therefore be a bit harsher? Is there  sweet middle ground? Or not? Lol.
Where all my moneys went.
Re: Raising coilovers, harsher ride?
« Reply #1 on: 23 February 2011, 23:31 »
It will be softer if you raise it up, mine was.   :smiley:
Offline Gash
« Reply #2 on: 23 February 2011, 23:34 »
mines about 70mm up. so around 80mm in height at the front and no bouncyness at all really nice ride. so should be good!
Offline lemski
  • 16v
« Reply #3 on: 23 February 2011, 23:40 »
If my mum drove mt car, ikd leave it decked. But mines real harsh so raising it up would be good to soften it. All depends what coillies for how soft there gunna be though
Offline Khare
  • The bear that khares
« Reply #4 on: 24 February 2011, 00:10 »
This.
Springs are for height, dampers are for damping. The more squashed the damper is (lowered) the more compacted the oil/gas will be resulting in a firmer ride. Think of it like a syringe full of air, the more you squeeze it, the harder it will be.
Offline Bellend
« Reply #5 on: 24 February 2011, 18:06 »
Cheers guys, I get all that but was just thinking as it compresses so much, there is less room to travel to a certain extent but I've worked it out in my head.  :grin:
I assume the coil is just long enough to get all the spring travel even at the highest setting.
