Author Topic: Changing rear drum to disc  (Read 911 times)
Offline vw golf dubber
« on: 23 February 2011, 22:18 »
what are the steps to changing rear drum to disc. do only have to change disc hub or hole beem brake lines and evrythin? no opinions jus how.
Re: Changing rear drum to disc
« Reply #1 on: 23 February 2011, 23:07 »
Basic beam is the same so your looking for discs, stub axles, handbrake cable and brake lines also worth fitting a set of new rear wheel bearings as well.
« Reply #2 on: 24 February 2011, 09:04 »
plus a bias valve if you dont have one fitted, its on the passenger side just in front of the rear wheel with a massive spring between it and the beam
