Author Topic: heater  (Read 875 times)
Offline searaj
heater
« on: 23 February 2011, 16:31 »
Can anyone help pls my mk3 blowing cold air out but when I rev the car it blow out warm but as soon as I drive the car it blow out cold its a 1.4
Offline Seanl
Re: heater
« Reply #1 on: 23 February 2011, 16:38 »
Is your thermostat reaching the right temp? or have you recently replaced the coolant? or does it smell of coolant in the cab?
could be a few different things mate
Offline Khare
  • The bear that khares
Re: heater
« Reply #2 on: 23 February 2011, 16:40 »
Hmmm, does the car overheat at all? Water pump could be faulty.
Offline Gal
Re: heater
« Reply #3 on: 23 February 2011, 16:56 »
Mine is the same. Not yet changed thermostat as that sounds like it's staying open so not letting the water get to temperature
Retro_look
Re: heater
« Reply #4 on: 23 February 2011, 19:35 »
as said, are you noticing any coolant loss? are both the top and bottom hoses on the radiator getting hot when car is at running temperature?
Re: heater
« Reply #5 on: 24 February 2011, 09:02 »
