Poll
Hi can anyone describe to me where the thermostat is on my Golf
Thermostat
0 (0%)
Cold Air
0 (0%)
Total Members Voted: 0
Author Topic: Thermistat Golf 1989 1.8 GTI 16V  (Read 2131 times)
Offline Trenerry
« on: 23 February 2011, 10:44 »
Hi My 1989 mk2 golf gti 1.8 16v is blowing cold air and when car is sat idol is boiling itself as the radiator fan is not kicking in. Its as if the water reaches the radiator but decides dot to flow round it so decides to push the water back into the bottle till it over flows. If anyone has had this problem please could you help me out. Also I need to find where the thermostat is if anyone can help me out with that too?
Cheers.
Offline rob.043
Re: Thermistat Golf 1989 1.8 GTI 16V
« Reply #2 on: 23 February 2011, 11:24 »
 its on the water pump flange (if its the same as my 8v). so if the bottom hose to the radiator stays cold, it is the termostat.
Cold air from the interior heater is a seperate issue due to blocked heater matrix or failed heater by-pass valves. A suitable search of the mk2 section will provide answers and guides on repair
Offline Trenerry
« Reply #3 on: 23 February 2011, 11:33 »
I know the pipes become hot very quickly even the bottom pipe on the radiator. I have been switching engine off when temp gauge is nearly to the max. There are no bubbles in the water when reving it. already has the blue cap on too. Seems to boil itself at the mo before the radiator becomes warm, but radiator does eventually get hot after it nearly decides to boil itself.
Offline rob.043
« Reply #4 on: 23 February 2011, 12:35 »
If the engine is overheating and the radiator is cold then the thermostat must be at fault  :undecided:
« Reply #5 on: 23 February 2011, 12:37 »
or possibly the waterpump, or an airlock or...
hence the link to the coolant guide, go thru that and you'll figure out which of the above it is ;)
Offline Trenerry
« Reply #6 on: 23 February 2011, 18:17 »
Thanks for all the help so far will check tomorrow if I can as im not so mechanically minded. If you think of anything by going into detail please let me know. Thanks again so far for all your help. Please keep an I on my post as no doubt with my luck will need more advice  :undecided:
Offline Trenerry
« Reply #7 on: 23 February 2011, 18:59 »
How do i save these forums people have sent me so I can find what people have wrote to me alot easier.
Tren
Offline Trenerry
« Reply #8 on: 23 February 2011, 20:09 »
Ha managed to upload a photo after several attempts but how do I make it smaller??
