Author Topic: mk2 wiring problem  (Read 1814 times)
Offline bosco
mk2 wiring problem
« on: 22 February 2011, 22:33 »
In the middle of a 1.8 20vt project and it started for the first time yesterday. Was putting the dash back in today and and was putting the light switch back in on the right hand side of the dash and it sparked when I pressed it by accident and now it wont start. Does that sound like a fuse gone? Any help would be great I have no idea what im doing at all.
Ross
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Re: mk2 wiring problem
« Reply #1 on: 23 February 2011, 00:02 »
Yes check fuses if not you may have burnt some wiring.
Offline bosco
« Reply #2 on: 23 February 2011, 00:19 »
Thanks Wayne appreciate it. If I have burnt some wire would it be close to where the sparks were or could they be anywhere?
1990 mk2 1.6 daily
« Reply #3 on: 23 February 2011, 09:33 »
Could be anywhere, start at the switch and work back.
Offline bosco
« Reply #4 on: 23 February 2011, 10:31 »
Cheers Wayne thanks
1990 mk2 1.6 daily
Offline bosco
« Reply #5 on: 23 February 2011, 21:01 »
Ok I had blown a fuse but now my dips and headlights work but my normal ones dont. Any more ideas? cheers
1990 mk2 1.6 daily
Offline emery1990
« Reply #6 on: 23 February 2011, 21:03 »
have you checked the wiring, maybe too the normal ones are damaged?
Offline mk2bal
« Reply #7 on: 23 February 2011, 21:23 »
if it is a swich/switch wiring problem you could prove the continuity of them all with a multimeter.test them from the switch plug to the plug at fuseboard end to make sure one didnt burn out. also check other fuses because they may be fused separately?
Offline bosco
« Reply #8 on: 23 February 2011, 21:56 »
Cheers guys il try check them tomorrow.
1990 mk2 1.6 daily
