Author Topic: problem help please  (Read 805 times)
Offline on-the-rampage
problem help please
« on: 22 February 2011, 20:11 »
right just fitted my momo wheel and boss but i have no horn now (there was 2 pins on the back of the horn but only one wire coming out of the column)
also when indicator is on when i turn the wheel the dont switch off automatic)
cheers
NOT NOW CHIEF I'M IN THE f**kING ZONE
Offline trog_nfs
Re: problem help please
« Reply #1 on: 22 February 2011, 21:11 »
you need to earth one of the pins on the back of the horn, just stick a ring connector on a little bit of wire and earth it to the boss. Might need to rub a bit of paint off.
As for indicators, there should have been a pin the goes in a small hole on the bottom of the boss (bit furthest away from the wheel). This self checks the indicators.
« Reply #2 on: 22 February 2011, 21:21 »
yeah there was 2 pins but didnt know what they were for ill have to take it apart tomorrow again
« Reply #3 on: 23 February 2011, 09:55 »
make sure that when you fit the momo boss the indicator cancel pin on the back is in the same place as it is on the old wheel. since you can fit the boss any way you like its possible to get the alignmane of the release pin wrong then the canceling wont work right
