Author Topic: Leak by the ECU...  (Read 1138 times)
Offline twistedblack69
  • Proud mk2 user and abuser
Leak by the ECU...
« on: 22 February 2011, 16:12 »
I've taken the carpet and sound deadening up and I've found a leak coming down right in the corner by the bonnet pull. It seems to be following the wires, so I assume it's coming through the scuttle panel/bulkhead where the ECU wiring comes into the car. Has anyone had this leak, and/or does anyone know how to sort it? I haven't got round to taking the ECU out and having a look, 'cause a) I don't know how and b) I don't know if this'll fcuk anything up.
Re: Leak by the ECU...
« Reply #1 on: 22 February 2011, 20:46 »
Could be the grommet has split.
« Reply #2 on: 23 February 2011, 10:02 »
removing the ecu is no big deal, it hasnt got any memory or anythign so it wont loose any settings. just unplug it, put to 1 side then plug it back in when you're done. take out the whole ecu tray, theres a plastic nut in the front passenger side corner, then you give it a good shove backwards to release the clips. then its a case of squeezing it out, bit of a tight fit.
its more liekly to be the bonnet pull cable tho, so give it a smear with a load of grease all the way round to seal up any cracks. if that helps look into buying a new one later. if it doesnt help, it might be the blanking plate under the ecu. there is a big plate stuck down over the LHD fresh air blower hole, the sealnt may have gone or some rust may be creeping in
« Reply #3 on: 23 February 2011, 20:25 »
You are a god! Thank you, I'll check it out.
