Hello all,
Just picked up this beauty off eBay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320657270530&ssPageName=STRK:MEWNX:IT#ht_735wt_1032As you can see from the description it's got what seems to be the common stalling at junctions problem with the flashing oil and battery lights. Sometimes it saves itself, most of the time not. It is idleing around 500rpm on tick over and a bit lumpy.
I have purchased the following in a bid to cure it:
no.30 ECU relay
Coil pack
Crank angle sensor
Carb cleaner for the throttle body
I have read some people suggest you disconnect the battery for half and hour when you replace the ECU relay and some say not to bother. What do you guys think is the best option?
If that fails am I right in thinking that I need to look into the vacuum hoses and that?
Other than that I am looking to replace the missing door trim and the cracked indicator lenses which I have already picked up.
Then long term will be looking for some BBS's and lowering it a touch.
Look forward to joining in here when I can.
Thanks,
Dan
