Author Topic: 256mm Upgrade  (Read 1433 times)
Offline Defender
256mm Upgrade
« on: 22 February 2011, 12:45 »
Hi All,
I've bought a 256mm upgrade for the rear of my PD150 but I remembered reading somewhere about the splash guards being the wrong size.....seems obvious, but I also remember something about replacing bearings if you remove them. Sorry it's bit vague can't remember where I saw the info. Does anyone have a guide to fitting these and exactly whats involved?
Also I don't have the right size splash guards with everything I've bought....should I buy them or will it be ok without?
Thanks,
Offline tech1889
  • Mk2 GTI FTW !!
Re: 256mm Upgrade
« Reply #1 on: 22 February 2011, 12:50 »
will be fine without splash guards.. you can also mod the old ones i think..
do a search should be a guide on here somewhere !
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: 256mm Upgrade
« Reply #2 on: 22 February 2011, 15:19 »
basically just get some tin snips and cut the lip in places all around the guard and then just fold the lips back. Job done and you dont have to remove the guard.
Offline houston
Re: 256mm Upgrade
« Reply #3 on: 23 February 2011, 10:01 »
most people recommend replacing the wheel bearings cos when you strip all the brakes your bound to get contaminents in there and theyll break soon after. there not that expensive so id do them while everythings in bits.
Offline Hulmie
Re: 256mm Upgrade
« Reply #4 on: 23 February 2011, 11:34 »
shouldnt really get any contaminents when changing the brakes as its a straight forward job. Disc's off, new mounting brackets on, rewind caliper piston, replace pads, fit new disc's and calipers. job done
Offline houston
Re: 256mm Upgrade
« Reply #5 on: 23 February 2011, 11:45 »
in theory no, but in reality how much crap comes off when you take brakes to bits? and its all fine dust that makes its way into everything.
there not an expensive part, makes sense to do them when there right in front of you
Offline Defender
Re: 256mm Upgrade
« Reply #6 on: 23 February 2011, 12:49 »
Thanks for your help and replies everyone much appreciated.
Unfortunately some ejit decided to re-arrange the front of my car last night so the brake upgrade is going to have to wait until it's repaired by the insurance company  :sad:.
Offline tech1889
  • Mk2 GTI FTW !!
Re: 256mm Upgrade
« Reply #7 on: 23 February 2011, 15:35 »
sorry to hear that mate..
