Author Topic: Fitting a stainless exhaust  (Read 4218 times)
Offline dkw
« on: 21 February 2011, 21:46 »
The last time I fitted an exhaust everyone was using jointing paste (yep i'm old), but I know my mates who work in the exhaust place on the high street use clear silicone. What's the best thing to use when fitting a stainless system?
Currently : 1999 MK4 1.8t Gti AGU 5 Door In Black, Pipercross Panel Filter, Full Milltek De-cat system, 4mo rear valance.
Previous Dubs : 66 Splitty, 55 Oval Beetle, 68 Beetle, 69 Beetle, 71 Beetle, Mk1 Scirocco, T25 Camper, 89 Golf Synchro 4x4, 91 Golf Driver, MK3 8V Golf Gti.
Re: Fitting a stainless exhaust
« Reply #1 on: 21 February 2011, 23:39 »
Exhaust paste, why would you use silicone, that is nuts.
Offline AudiA8Quattro
« Reply #2 on: 21 February 2011, 23:56 »
Do people not use paste anymore? why?
« Reply #3 on: 22 February 2011, 00:02 »
Have also seen stainless systems fitted without paste as they seal when they warm up or so I was told.
Offline Khare
  • The bear that khares
« Reply #4 on: 22 February 2011, 00:07 »
+1.
I don't run any paste on my stainless system, and it doesn't blow  :smiley:
Found this on matey matey though.
Quote
Once the old exhaust is off the car you should offer the new system up and bolt it loosely in place. Apply regular exhaust assembly paste to any joints if fitting a mild steel exhaust but use clear silicone sealant on stainless exhausts. It may sound odd but the regular assembly paste does not stick to shiny stainless steel.
« Reply #5 on: 22 February 2011, 00:10 »
Interesting info with silicone and stainless systems thenĀ  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 22 February 2011, 13:29 »
sooo true wayne! this guy that does stainless steel uses clean silicone and has never had any probs. he said that the prob with the exhaust putty is that after a while it starts to get brittle and fall apart. obviously the silicone will need to withstand certain temps
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Khare
« Reply #7 on: 22 February 2011, 14:31 »
Why use silicone at all though?
If the exhaust is of good quality and it's fitted properly it causes no problems. Mine has no putty or silicone and it doesn't blow at all.
« Reply #8 on: 22 February 2011, 18:26 »
If you are fitting one pipe over another, its difficult to get 100% gas seal.
Flange fitting exhausts are much better  :grin:
