Author Topic: Diagnosing PD150 camshaft failure  (Read 3526 times)
Offline Dan_GTI
  • GTi addict formally known as yoof
« on: 21 February 2011, 14:10 »
ive posted twice on the rattling i had which was thought too be DMF failure so... i had a new DMF and clutch fitted and the problem is still here, on idle the engine sounds as if it trys too stall very slighty and theres a small clunk also when the engine is turned off theres a clunk which only stops if the clutch pedal is pressed. Do i have the dreaded camshaft  :sick:?
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline Rhyso
Re: Diagnosing PD150 camshaft failure
« Reply #1 on: 21 February 2011, 14:12 »
Whip the rocker cover off and inspect the lobes and followers.  Look for any signs of abnormal wear or pitting
Fingers crossed you don't.......
Offline Dan_GTI
« Reply #2 on: 21 February 2011, 14:19 »
cheers mate, fingers double crossed  :sick:
Offline nadlad
  • Building Surveyor MRICS
« Reply #3 on: 21 February 2011, 21:55 »
this is the noise i had when mine went exactly ike this
http://www.youtube.com/watch?v=QuAfEKx84F4
<<<Big Build Thread>>>
