Author Topic: Retro fitting parking sensors  (Read 5432 times)
Offline Buck
  • Das Auto
« on: 21 February 2011, 12:51 »
Hi all
I'm toying with retro-fitting genuine parking sensors to my car
I've seen the sensors and control module on eBay. These are a front & rear set (not sure if they can be bought cheaper elsewhere as yet as only just started to explore)
Now I'd either have to drill the bumpers to fit and respray or buy new covers with the holes pre-drilled
Thoughts on this?
Thanks
Offline am1w
Re: Retro fitting parking sensors
« Reply #1 on: 21 February 2011, 13:02 »
Hi all
Thoughts on this?
Thanks
Just a thought: Have you thought of fitting the rear view camera instead? However, this does not work with the RCD310.
Regarding the parking sensors, better get it done professionally. Too much of a risk otherwise IMHO.
There are places that fit these and they do look OEM. When I explored this for a friend the cost I got was £400!
Offline Buck
  • Das Auto
« Reply #2 on: 21 February 2011, 14:35 »
Thanks Asker
I'd forgotten about the camera option. hopefully cheaper than £400!!
I'd need the RNS510 for this too!
Do you have the camera on yours?
Is it effective?
Thanks again
Offline am1w
« Reply #3 on: 21 February 2011, 14:46 »
Thanks Asker
Is it effective?
Thanks again
I've got front and rear sensors but no camera. I feel the sensors are good enough. The sensors show distances very clearly on the RNS screen and also showed distances (I think) on the RCD310 screen. They also have different sounding beeps for front and rear and the beeps sound from the rear for the rear sensors and from the front for the front sensors.
You'll have to price up the most economical solution for you. But, one thing is clear, either rear sensors or camera are very helpful. I also find the front ones worth having.
Gizzy, did not have sensors and installed the rear camera courtesy of Darren. She loves it.
There is one disadvantage of having sensors in the bumper. If you scuff the bumper, then depending on where the damage is, the bumper has to come off and the sensors removed for repair and paint due to the black rubber rings that hold the sensors in place. Otherwise, overspray could cover them. Without sensors, the bumper damage could be repaired in situ. With sensors, the repair can cost more!
« Last Edit: 21 February 2011, 16:40 by am1w »
Offline Buck
  • Das Auto
« Reply #4 on: 21 February 2011, 15:08 »
All good advice.
I might drop a PM to gizzy.
Thanks
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 21 February 2011, 17:22 »
I though the sensor bumper was different as the holes were countersunk?
Current Garage:
35+ years of GTI ownership.
Offline Buck
  • Das Auto
« Reply #6 on: 21 February 2011, 17:39 »
It is Geoff. Looking at photos I think they are fitted from the rear do not sure they are counter sunk. I Need to look at one in more detail!
Offline am1w
« Reply #7 on: 21 February 2011, 17:39 »
That too. :smiley:
Better to go for the reverse camera in Buck's case IMO.
Offline RedHP
« Reply #8 on: 21 February 2011, 20:42 »
Sorry guys slightly off the topic, but when I passed my test 16 years ago there were no sensors and we had to park using our judgement. I have had sensors on my last 2 cars over the last 6 years and can't believe how much I rely on these. I am deteriorating......!!!!!!!!  :sad:
Mk6 GiT since birth in 2010
YNWA
Offline am1w
« Reply #9 on: 21 February 2011, 20:47 »
We all are mah deah, some more than most. :cry:
