Author Topic: cuttin out while drivin problem HELP PLEASE  (Read 1442 times)
Offline on-the-rampage
« on: 20 February 2011, 17:20 »
ive got my mk3 golf it will idle for ever but as soon as your driving it when warm it cuts out then starts again after a few mins i've just had it running for a hour outsde my house touched no 167 relay and its really warm should it be and will this be causing the problem
what is 167 rely for
help please
NOT NOW CHIEF I'M IN THE f**kING ZONE
Offline Walkerboy
Re: cuttin out while drivin problem HELP PLEASE
« Reply #1 on: 20 February 2011, 19:54 »
its not when ur slowing down in traffic or when u pull away in a queue is it dude????
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 20 February 2011, 20:00 »
Crank speed sensor.
« Reply #3 on: 21 February 2011, 07:19 »
just when i drive normal up the road just cuts out
Offline Seanl
« Reply #4 on: 21 February 2011, 08:44 »
Check your air inlets and maf. When u disconnect the maf it will still cut out but if it runs much better, that could be ur problem. I had it when I was fiddling with my airbox, and the air inlet pipe came loose from the throttle body. Worth a check anyway!
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
« Reply #5 on: 21 February 2011, 20:03 »
Sounds like its the coil pack on its way out to me.Same thing happened to my golf and only found out wot it was until the coil pack completely died.
Retro_look
« Reply #6 on: 23 February 2011, 19:45 »
+1 had exactly the same syptoms, started out just cutting out in traffic and at junctions ect, slowly got harder to start when left for afew days, untill one morning she wouldnt start at all, i checked for spark with a plug in the HT lead, nothing! i had fuel delivery as the plugs were wet so wasnt going to be crank sensor as that cuts both spark and fuel. Fitted coil and she started up on the button, no problems since!
« Last Edit: 23 February 2011, 19:49 by Retro_look »
Offline Chew22
« Reply #7 on: 24 February 2011, 15:35 »
help please
167 is the fuel pump relay, this is supposed to be warm.
If your car is a little spluttery when it cuts out, its likely the Crank sensor. It's a b!tch to change, but it is worth taking out and inspecting at least. When i removed mine all the wires were blended into one and i'm surprised the car even started.  Changed for a genuine replacement part and problem solved (£65 and fitted myself). I have a good photo of my f**ked crank sensor here. http://www.golfgtiforum.co.uk/index.php?topic=172870.msg1644742#msg1644742
I also had a cut out problem where the car would just cut out dead as if I just turned the key off. No spluttering, just dead. It usually took about 2-10  mins to restart and it would do it every 20 mins or so. After it cuts out and wont start again, can you hear the fuel pump prime (a humming from the rear of the car for around 2 seconds) I changed the ECU relay (number 30) and so far, problem solved. Was £11 from europarts, and I think £20 for genuine. It's a very cheap and easy to switch part to try first. If no fix, just switch back and sell relay online.
Hope this helps
« Reply #8 on: 24 February 2011, 18:51 »
right ive had my car down g/f  dads garage today changed the relays had it on computer come up with 2 problems not sure what they were but he says he sorted them so anyway he took the car out and still cuts out he has come to the conclusion its the ECU needs fixed so he says hes giong to send it away so i'll just have to see when that is back
Offline Leebob
« Reply #9 on: 24 February 2011, 20:24 »
Btw a problem with the coilpack will not show up as a fault on the computer.As i said before,if it is the problem you will only defo know when it completely packs up.
