Author Topic: Door pump pipe loose in the electrical coupler.  (Read 827 times)
Offline Mr.Tom
« on: 20 February 2011, 10:58 »
The central locking pipe has come loose in the white connector block from the door to the car. Where you screw the contacts together. It has popped back into the connector.
When I unlock, the pump keeps running until I start the engine, or I open the passenger door, and there is a "psst" where the pipe pops out of the seal.
Any ideas how to fix it? It looks a little like there should be a clip or something to hold it (perhaps I should go look at the drivers side now I come to think about it :) )
Cheers.
Offline forsh
Re: Door pump pipe loose in the electrical coupler.
« Reply #1 on: 20 February 2011, 12:31 »
same happened to me,but im lhd car
so my passenger pipe popped back in the connector
all i did was epoxy on the back bit and hold it in place a few seconds,its right now
i got the big connector out the socket its in and pulled the rubber boot off ,to see the pipe and wires
Offline Mr.Tom
« Reply #2 on: 02 March 2011, 16:39 »
Glued it back into place, but the problem still occurs. although, not had the pressure release when I open the door all the way now.
It would mean a whole new door loom to replace it wouldn't it? Seems to be one part.
