Author Topic: Fixing left rear speaker mount.  (Read 1523 times)
Offline thestat
« on: 05 March 2005, 22:11 »
Hi,
I have just recently bought a 1989 1.8 GTi 8v and it needs a few things doing on it, one of the annoying things that needs to be done is the left rear speaker mount.  Looks as if the previous owner had a break in and someone tried to rob his speakers, as the plastic lugs, the actual metal speaker brackets go onto, have been cut off.  I still have 2 of the plastic lugs, all the plastic stoppers, but only one metal nut/fixer that holds the speaker up.
Was thinking of trying to glue the 2 remaining plastic lugs back on, but I still have the problem of the missing metal nut/fixer.
Anyone who has any suggestions to this problem I would be happy for your advice
Offline Mr Blue
Re: Fixing left rear speaker mount.
« Reply #1 on: 05 March 2005, 22:24 »
take a metal bolt off the parcel shelf supports and use it as a speaker bolt.
Should hold the speaker on :wink:
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« Reply #2 on: 06 March 2005, 14:37 »
A second hand one should not cost alot of money from a breakers. They are easy to take off and swap too... You can get the correct nuts from vw still they r next to nothing aswell...
Offline thestat
« Reply #3 on: 07 March 2005, 11:22 »
Thanks for the advice guys will get a new one or try using a parcel shelf bolt.
One other thing, is it easy to acquire the bulb for the boot lamp?
Offline ...joe
« Reply #4 on: 07 March 2005, 16:13 »
go to a scrap yard to get the parcel shelf support, making sure you get one thats intact!! :wink: and go to any motor factors or halfords to get a bulb. cheap easy and redily available!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
