Author Topic: How do you make the clutch pedal on a mk2 smooth  (Read 2542 times)
Offline Adamdubz
« on: 18 February 2011, 17:53 »
Mine is sticky and it sucks   :sad:
Offline The Mighty Elvi
  • I'm better than you today.
Re: How do you make the clutch pedal on a mk2 smooth
« Reply #1 on: 18 February 2011, 17:54 »
Do you literally mean the clutch pedal, or making the action of the pedal smooth?
Offline Adamdubz
« Reply #2 on: 18 February 2011, 18:04 »
the action like moving it up and down
« Reply #3 on: 18 February 2011, 18:19 »
Open the bonnet and have a play with the clutch lever.  That should tell you if its the clutch mechanism that is sticky, or the cable and pedal.
Offline Adamdubz
« Reply #4 on: 18 February 2011, 18:21 »
where abouts is that ??? :huh:
Offline Adamdubz
« Reply #7 on: 18 February 2011, 19:02 »
thanks will take a look in the morn  :grin:
« Reply #8 on: 18 February 2011, 21:05 »
Or disconnect the cable and see what it feels like, cheap and easy enough to replace if you need to.
« Reply #9 on: 21 February 2011, 12:18 »
step 1: change the cable, give it a grease with some silicone spray lube
step 2: replace the clutch
