Author Topic: Golf Mk3 engine change  (Read 5677 times)
Offline CM690
  • Golf MK4
« on: 18 February 2011, 11:46 »
My MK3 Golf 1.4L isn't running at it's best if I'm honest :cry: It seems to run OK when it's cold but as soon as it gets warm acceleration drops considerably and any slope/hill i've had it. Revs drop fast and I'm lucky if I'm doing 15/20mph up a hill. Quite embarrassing when you have people flashing you behind you because you are going too slowly!  :drool:
The engine has a ticking sound which doesn't sound very healthy and the oil pressure light is on most of the time (changed sensor and has plenty of oil, never lost oil) so I'm assuming I'm just losing pressure. My dad being a mechanic told me the engine is getting tight when it warms up putting stress on the engine causing it to lose so much performance.
To the point, I'm considering changing my 1.4 petrol engine to a 1.6L golf mk3 engine of the same year. It's only done 73,000 mile which is around 15,000 less than mine.
Would this be possible? Almost a "straight swap" if you will? or will I come across a lot of problems? I was going to opt for a 2.0 GTI engine but my dad told me that would be too much hassle and the insurance would go up a lot when I declare it being only 19 an all! The jump to a 1.6 doesn't cost me that much more on the £2000 premium I already pay so i thought why not  :grin:
What do you think?
Offline GrandMstRamRod
Re: Golf Mk3 engine change
« Reply #1 on: 18 February 2011, 11:53 »
red this thread
http://www.golfgtiforum.co.uk/index.php?topic=78315.0;topicseen
LazyLunatic's thread
turned his 1.4 into 1.8t
alot of work and alot of money needed! :P
but good luck!
« Reply #2 on: 18 February 2011, 11:56 »
Better off selling up and buying something else, fitting a 1.6 is a major ballache for so little gain.
« Reply #3 on: 18 February 2011, 12:03 »
unless u bought a doner car and basically swapped EVERYTHING!
« Reply #4 on: 18 February 2011, 12:09 »
It can be done that way but is it really worth it for 15bhp.
Offline Mike87Turbo
« Reply #5 on: 18 February 2011, 12:49 »
Alternatively i have a '94 1.4 8v lump lying around doing nothing  :wink:
PM me if youre interested  :grin:
Mike
Offline Len
« Reply #6 on: 18 February 2011, 13:22 »
If your Dad is a mechanic why cant he rebuild the existing engine?
And I've never heard of an engine getting tight! Unless it overheats!
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 18 February 2011, 13:47 »
the mk3 1.6 spi uses most of the same parts so it's not really involved to swap (you will need the ecu & key if from a 95 onwards car)
the fuel system, gearbox, brakes etc etc are all the same (I'm unsure of the cooling system though? but that would usually only involve the rad)
Offline CM690
  • Golf MK4
« Reply #8 on: 18 February 2011, 14:23 »
red this thread
but good luck!
Thanks I'll take a look at that thread now!  :smiley:
Hmm.. I'm not so sure, my current engine is running badly so even just a new 1.4 might make a difference to me.
He's not sure if it's worth it and I said for the few hundred quid he may as well put a 1.6 in :p I haven't heard about an engine getting tight either but apparently thats my dads diagnosis! :o
I don't have the ecu or a key for that engine. I will have to ask if the seller has it, if not should I stay clear?
« Reply #9 on: 18 February 2011, 14:51 »
You will need the ecu for the 1.6, still a 100% pointless swap
Have you checked your insurance.
