Golf mk1
golf mk1 rear axle
Topic: golf mk1 rear axle (Read 2939 times)
lord14
Here all the time
golf mk1 rear axle
17 February 2011, 20:36 »
bushes have gone and i need to change themm do i need to drop the beam off or not ?
SoundillusioN
10k hero
Re: golf mk1 rear axle
17 February 2011, 20:48 »
Quote from: lord14 on 17 February 2011, 20:36
Have a look
HERE
. A very recent MK2 thread on the same subject, it's the same job. It can be done in situ but is a bit harder.
Shaun
Now with added MK7
Forum Member Map
Mk1 Project Clicky
Mk1 Dub Rides Clicky
T25 Project Clicky
T25 Dub Rides Clicky
lord14
Here all the time
17 February 2011, 20:52 »
if i was to drop the axle off what bolts do i need to undo and do i need to undo the drum lines and handbrake cable
shepgti
17 February 2011, 21:39 »
im sure you could just undo the axle mount bolts and drop it down and leave the cables attached but it will be more fiddly doing it under the car rather than removing all togther
lord14
Here all the time
17 February 2011, 22:48 »
ooh right i may try it first see how it goes ,
Wayne
Sir Postalot
17 February 2011, 23:49 »
It is a lot easier to remove the beam, gives you more room to work.
Golf mk1
golf mk1 rear axle
