Author Topic: Lights in the MK2 Gti clocks?  (Read 2782 times)
Offline Gicho
« on: 17 February 2011, 16:09 »
Hi to all......I have a 16v MK2 and the head light (green i think) and the main beam light bulbs (blue) in the clocks don't work. I've stripped the clocks down and I can't see a way to replace these tiny tiny bulbs......I'm I wasting my time or can this be done? Its doing my head in because I don't know if I'm driving round with my main beam on or not.
Thanks
Gicho
Re: Lights in the MK2 Gti clocks?
« Reply #1 on: 17 February 2011, 16:24 »
they just pop out, you need to lift up the plastic holder thing first which is a bit fiddly. the green one is the indicator warning, the blue one is actually a small bulb rather than an led with a blue cap on it
Offline Gicho
« Reply #2 on: 17 February 2011, 16:34 »
the green one is the indicator as you said....the blue one has a blue cap over it and for some reason doesn't appear to be removable
« Reply #3 on: 17 February 2011, 16:54 »
it is removable, just a bit of clear plastic over the bulb ;)
as i say you need to remove the pblack plastic tray thing that goes over the bulbs, which can put up a bit of a fight, then the bulbs/leds pull out. they can put up a fight as well  :grin:
but dont give up, i had to pinch the blue bulb out of my spare mk2 16v clocks and fit my mk1 cabby clocks :)
Offline Gicho
« Reply #4 on: 17 February 2011, 17:29 »
where can I buy these tiny bulbs from.....does anyone know the name of them
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 17 February 2011, 17:41 »
For More Info Click To See;
Offline Gicho
« Reply #6 on: 17 February 2011, 18:08 »
I can't find these bulbs anywhere on the internet
Any ideas?
Offline midz16v
« Reply #7 on: 17 February 2011, 20:04 »
i mite have a spare blue one there still availible from vw as i changed my one in oct
Offline Gicho
« Reply #8 on: 17 February 2011, 20:34 »
NO WAY!!  How much? Do you have the part number or part description?
« Reply #9 on: 18 February 2011, 11:53 »
357 919 062 - bulb with blue cap - 3.25+VAT
