Author Topic: Converting to electric windows?  (Read 772 times)
Offline LowlifeDubber
« on: 16 February 2011, 15:46 »
It's proably been covered before but i cant find it via the search function before you throw stuff at me.
Car is a 1993 mk3 Golf Driver with manual windows.
Both doors are going to be changed shortly before it's respray and im obviously going to convert to lazy electric windows.
My questions are:
Is it a case of getting the window regs,loom and switches and will it just be plug and play into the back of the mk3 fusebox ive got?
Id rather not retro fit some,which i can do easy as id rather do it using original parts.
Are the looms seperate?Will i have to fanny about with the door sockets?ie pin them either side to make a contact etc.
Re: Converting to electric windows?
« Reply #1 on: 16 February 2011, 21:17 »
Yes you will need the loom, switches and regs etc and it is I believe plug and play.
« Reply #2 on: 16 February 2011, 21:28 »
Ahh luvly.Do you know if the  window loom is seperate?Is there a control box on the mk3 for it all,or just a thermo cut out type fuse?
« Reply #3 on: 16 February 2011, 21:29 »
Not sure, Brad (kells) added electric rear windows, might be worth dropping a pm.
« Reply #4 on: 16 February 2011, 21:41 »
Lovely job,will do cheers.
