Author Topic: uh oh, gear selection probs  (Read 1512 times)
Offline spear
« on: 16 February 2011, 09:26 »
Morning peeps
So yesterday i get in the golf to drive to work and found it to be quite stiff putting it into 1st gear, thought nothing of it and proceeded to drive off when it popped out of gear. It did this a couple of times in 1st but not any other gear i used. It was fine the night before when driving home.
After work yesterday I drove about 5 miles to the gym and had a few issues with popping out of 1st and 5th and it generally stiff selecting any of the forward gears, 1st 3rd and 5th. When i put it into one of these gears I can select them ok, no grinding but it feels as though the gearstick is at the limit of its movement and feels like it wants to pull itself out of gear, if that makes sense.
Obviously I'd like to get to the bottom of this and so where should i start? Could it be the gearlinkages need adjusting? I changed the front engine mount a couple of weeks ago and wondered if jacking up the engine might have affected the alignment of anything, there is still movement so the other two mounts need looking at.
Am i just in denial that a new gearbox is going to be needed?
Any help is appreciated as I know very little about gearboxes, linkages etc.
« Last Edit: 16 February 2011, 10:16 by spear »
Offline N900 MJT
Re: uh oh, gear selection probs
« Reply #1 on: 16 February 2011, 09:45 »
Offline spear
« Reply #2 on: 16 February 2011, 09:58 »
I've looked at that thanks mate, didn't make a great deal of sense  :laugh: i'll keep reading until it does.
Done plenty of searches, always do, but it's sometimes difficult to find exactly what you're looking for, especially when you're not 100% sure what to search for in the first place, hence the reason to post.
just thought someone may recognise the problem and know its something in the gearbox for example before i spend time trying in vain to fix it  :embarassed:
Offline N900 MJT
« Reply #3 on: 16 February 2011, 10:20 »
Hi mate - i had similar problems to you and did find that the first thing i posted helped, however have you tried the clutch cable fix?
« Reply #4 on: 16 February 2011, 10:21 »
what car is it?
Offline spear
« Reply #5 on: 16 February 2011, 10:32 »
sorry, 96 GTI 16v.
« Reply #6 on: 16 February 2011, 10:41 »
try zis:
Quote
The mk.3 16v has the same type of gearbox as the VR6 (and Tdi for that matter), the '02A'. You can check the transmission by selecting at the so-called 'tower' mechanism on the gearbox. Look for the balance weight on it, which looks like the head of a golf club. It has the two cables from the gearlever inside the cabin attached. The lateral cable adjustment might have slipped. When this happens, then basically the gear lever and gearbox selector are out of phase, and selection problems occur.
selecting gears at the transmission
Get hold of the weight and use it to push the selector mechanism right down, which is meant to correspond with the lever being at the left side of the 'gate'. Then move the weight (and the lever it's bolted to) CCW, towards the engine block, to select reverse gear. If the ignition is On, the reverse lamps should light when you find reverse. If it's not possible to get reverse, check for damage to the plastic/metal 'U' bracket which lifts and lowers the selector mechanism, or the adjustment nut being loose in its slot. If necessary, carefully detach the lateral cable by lifting the retaining clip and slipping the cable end off its peg. Then try selecting again. If you can now get reverse, the selector adjustment is at fault, but if not, check that the selector mechanism is firmly attached to the transmission. If it is, suspect the transmission.
Selecting 5th gear is similar, but lift the selector to its upper limit and then turn ccw.
home adjustment method
The gear selector mechanism is sprung to return to the mid-point between 3rd and 4th, so the main thing is to attach the cables to the gearbox selector with the gear lever at the same point. Moving the gear lever forward/back moves the lower cable (at the gearbox) to turn the selector lever, with the weight, cw/ccw. Moving the gear lever across the gate lifts the selector mechanism up/down using the upper cable and a relay lever - watch as someone moves the lever from side to side. Adjustment of this cable is done by moving the flanged nut along the slot in the relay plate. There is a special jig used by garages to hold the gear lever while adjusting the cables, but it is possible to get the adjustment right wihout this by trial & error; the plastic part of the relay lever seems to have quite a 'flex' in it, which has to be allowed for.
The lower cable is adjusted, if necessary, by loosening its attachment bolt and sliding the head of the cable along the edge of the selector lever; a caged nut inside a track on the lever moves while the bolt is loose. Adjustment is ok when the gear lever can be moved across the gate with the transmission in neutral, without having to move it forward or back.
But since you mention 3rd/4th selection is alright, with luck you'll only need to repair/adjust the relay lever. With the upper cable detached from the gearbox, and after replacing any broken relay lever parts, place the adjustment nut half-way along the slot. Put the transmission into either 3rd (ccw) or 4th (cw) and select the same gear on the gearlever. Then carefully re-attach the upper cable to its locating peg, so that the gear lever and selector are fully connected again. Move the gear lever out of the selected gear; it shouldn't move sideways, but remain lined up on 3rd/4th. Any sdieways movement can be corrected by slightly loosening the adjustment nut and moving it along the slot, allowing for the tension in the linkage. The direction of adjustment depends on which way the gear lever requires alignment. F'rinstance, if the gearlever lies too far to the left, move the nut slightly to the left in the slot.
Offline spear
« Reply #7 on: 16 February 2011, 11:36 »
cheers.
I'll have a bash at the linkage and see whts what.
might be a silly question but can knackered engine mounts affect the gear linkage much? there's a fair bit of movement which feels like a judder when pressing or releasing the throttle.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 16 February 2011, 12:57 »
It certaintly won't be helping matters. Have you also considered changing the gearbox oil?
Offline spear
« Reply #9 on: 16 February 2011, 13:04 »
something else I've never changed before!! yeah considered this so will have a go at checking the level and maybe changing it. no idea if its ever been changed so maybe a good idea to do this  :rolleyes:
every day is a school day with my car!!
