Author Topic: vr6  (Read 1793 times)
Offline kailola
vr6
« on: 15 February 2011, 19:36 »
hi guys this question has probaly come up alot but my fan comes on and does not go off help
mk4 1.8t oetinnger bodykit 19 inch split rims .. remap uprated turbo bailey dump valve custom s/s exhaust 240 bhp
Offline justalex81
Re: vr6
« Reply #1 on: 15 February 2011, 19:45 »
yes
Offline Khare
  • The bear that khares
Re: vr6
« Reply #2 on: 15 February 2011, 19:55 »
Something wrong there, and probably the thermoswitch in the radiator (which controls when the fan should come on/off) is faulty  :smiley:
Re: vr6
« Reply #3 on: 15 February 2011, 21:06 »
Faulty switch in the radiator, unplug it and see if the fans stop
Have you got air con, if so switch it off and see if they stop.
« Last Edit: 15 February 2011, 21:28 by Wayne »
Offline AlexMozza
Re: vr6
« Reply #4 on: 15 February 2011, 21:26 »
My Dads 307 does that, stay on for about 5mins after car stops :), disconnecting the battery works :)
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: vr6
« Reply #5 on: 16 February 2011, 06:57 »
The fan will start or continue to run on many cars once its turned off, remember it's whole point is to cool the engine down when there is no cold air rushing over it whilst driving.
Re: vr6
« Reply #6 on: 16 February 2011, 10:12 »
it may be the rad fan after-run switch wire has snapped off and earthed itself, though i dont know where this is on a vr6 or if it even has one? there is a separate temp sensor on the engien for the 3rdfan speed and i think electric coolant pump somewhere too.
but as above it is supposed to come on after switch off for a bit, but if it stays on for hours something is wrong somewhere
Offline tshirt2k
  • Been there...Done that...
Re: vr6
« Reply #7 on: 16 February 2011, 10:19 »
There should be one on the vr6. 16v mk3 have them. Same basic electrics. Usually on the inlet somewhere.
Mk3 ABF 16VT Megasquirt V3
Re: vr6
« Reply #8 on: 16 February 2011, 10:41 »
yeah i wasnt sure if that function was taken over by the auxilery coolant temp sensor? because there isnt an over-run switch mentioned on the vr6 rad fan diagrams see
Offline tshirt2k
Re: vr6
« Reply #9 on: 16 February 2011, 10:58 »
maybe. But then again from the run on diagrams i couldn't work out the run on worked for mine. Still haven't heard it kick in once engine is off after the temp has risen on heatsoak.
Do you know what temp the after run switches on at? may have a dodgy switch. Got it from danster from an older car. May try my ABF one as i know that used to kick in.
