Author Topic: Applying Polish  (Read 3688 times)
Jimmymature
Applying Polish
« on: 15 February 2011, 17:29 »
Hi guys, what's the best way to apply Auto Glym Super Resin Polish?
I have either:
Megs Microfiber Applicator Pads or
Megs soft foam applicator pads
Advice would be appreciated.
Jim
Offline Jimble
Re: Applying Polish
« Reply #1 on: 15 February 2011, 17:57 »
I personally use a damp megs foam pad, whether it's the best way to do it i've no idea but works ok for me. :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Applying Polish
« Reply #2 on: 15 February 2011, 19:30 »
I do same as above and it works for me with no problems
Offline Uruk Hai
Re: Applying Polish
« Reply #3 on: 15 February 2011, 21:06 »
I use a damp MF applicator pad, works very well when really working the polish.
Jimmymature
Re: Applying Polish
« Reply #4 on: 16 February 2011, 12:40 »
What's the reason behind using a damp mega foam pad? And how damp is damp?
Cheers,
Jim
Offline Jimble
Re: Applying Polish
« Reply #5 on: 16 February 2011, 16:44 »
Cheers,
Jim
Initially it was recommended on here to me, the reason being it gives a bit more even coverage as well as the polish not being quite as dusty when you buff it off, seems to do the trick plus you don't have to use as much cos it goes further! When i say damp i just have a little tub with water in, drop the pad in and squeeze it a couple of time so it's ringing wet and then squeeze it out, not wet "DAMP"  :wink:
Jimmymature
Re: Applying Polish
« Reply #6 on: 16 February 2011, 19:35 »
Cheers,
Jim
Thanks for the advice mate.
Jim
Jimmymature
Re: Applying Polish
« Reply #7 on: 22 February 2011, 15:23 »
When using my Dodo Juice wax should I also dampen the Megs sponge to apply it also?
Cheers,
Jim
Offline Jimble
Re: Applying Polish
« Reply #8 on: 22 February 2011, 18:53 »
I do mate but i use the dodo juice finger mitt foam applicators instead, only because i find it easier to get the wax out the pot! :wink:
