Author Topic: Bloody starter Motor or maybe wiring  (Read 3394 times)
Offline Steupton
« on: 15 February 2011, 12:05 »
alright.....dont think its an actual starter motor problem but whats happening is......whn you turn the key the car struggles to turn over like the battery is flat. but i asure you it isnt. it like there isnt enough charge going to it from the battery. is this just a wiring issue? cause tbh i can remember changing the starter and thinkin those wires look a bit fooooked. plus ive taken off the gbox earth cleaned it up and still the same any ideas?
Re: Bloody starter Motor or maybe wiring
« Reply #1 on: 15 February 2011, 12:08 »
remove all the starter, battery and alternator wires, buff em all up till shiny and refit
Offline walchy01
« Reply #2 on: 15 February 2011, 15:06 »
Hi there
If you look on here for my post, I have the same problem, did all the cleaning of connection etc but did not resolve.... Just had my starter motor refurbed yesterday and to my surprise it was knackered, got it back half an hour ago so not had chance to refit to see if this has solved the problem..... Hoping it has :grin:
May be same problem, mine went from turning slowly to just clicking...
Offline Steupton
« Reply #3 on: 16 February 2011, 00:56 »
sound that. well ill take off the wiring and smarted it up. the + to the starter is frayed and is pretty knackered to be fare so i might change it if that dosnt help then ill swap the starter for  shiney new one.
Offline rich1977
« Reply #4 on: 16 February 2011, 08:29 »
mine used to do the same until i cleaned all the conections up and now its turns over fine.
Www.Internet-ink.co.uk voucher code RL15 for 15% off all pens,toners and ink cartridges including cannon Epsom dell and hp.
Offline walchy01
« Reply #5 on: 16 February 2011, 17:13 »
Steerer motor refurbed and back on the car, guess what ????
Still the same :cry:
Offline mattkh
« Reply #6 on: 16 February 2011, 20:48 »
Hi
Did you check the starter motor on its own before putting it on  the car ?
« Reply #7 on: 16 February 2011, 21:10 »
Have you had the battery tested.  :smiley:
Offline walchy01
« Reply #8 on: 16 February 2011, 21:13 »
No mate, got a good friend who is great at this stuff used to work for VW so gettin him onit tommorow....
Offline walchy01
« Reply #9 on: 16 February 2011, 21:14 »
Battery as new in January 2011....
