Author Topic: whining  (Read 2581 times)
Offline stainesy
whining
« on: 14 February 2011, 20:13 »
what cause a whining gearbox?
also what makes an engine whiny?
my car is very whiny
also my gearbox whines aswell
just wondered what causes it and how to stop it
Offline harlemex
Re: whining
« Reply #1 on: 14 February 2011, 20:23 »
worn bearings in both.
Offline stainesy
Re: whining
« Reply #2 on: 14 February 2011, 20:28 »
wich engine bearing would it be?
Re: whining
« Reply #3 on: 14 February 2011, 20:37 »
Could be any one, does it increase with revs.
Offline stainesy
Re: whining
« Reply #4 on: 14 February 2011, 20:39 »
Yes it does on tickover but when driving you can't reay hear it.
Re: whining
« Reply #5 on: 14 February 2011, 20:40 »
I would start with checking your alternator and cam belt tensioner.
Offline harlemex
Re: whining
« Reply #6 on: 14 February 2011, 20:40 »
Agreed with Wayne, good advice.
Offline stainesy
Re: whining
« Reply #7 on: 14 February 2011, 21:02 »
Ok will do. I need to replace the alternator anyway as mine in cracked all the way through on the braket bit.
Offline javalin
Re: whining
« Reply #8 on: 17 February 2011, 13:04 »
Change the gearbox oil (VW), and check condition of gearbox engine mount too.  Won't solve it, but made it quieter on mine.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Len
Re: whining
« Reply #9 on: 17 February 2011, 13:07 »
That would cause a whiney noise! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
