Author Topic: Solid Tappet Valve Shims - Supplier Required  (Read 3194 times)
Offline SoundillusioN
« on: 14 February 2011, 16:11 »
Hi, as per title, who supplies valve shims for 1983 DX Engine and what should I be looking for?  Can I buy them in a set of various sizes cheap enough or is better to find out what I need first?
Re: Solid Tappet Valve Shims - Supplier Required
« Reply #1 on: 17 February 2011, 10:25 »
Bump.....  :undecided:
« Reply #2 on: 22 February 2011, 16:05 »
nobody?  :sad:
« Reply #3 on: 22 February 2011, 20:41 »
Not sure, your going to need a selection so you can set them as you go.
Have you tried GSF or ECP.
Offline blans
« Reply #4 on: 25 March 2011, 00:11 »
shims available from here mate..
http://www.vwspares.co.uk/
and yeha i would measure them first as there is quite a range. sizes are in the haynes manual  :smiley:
« Reply #5 on: 25 March 2011, 00:49 »
Thanks, will have a look later.  My heads not standard but that only affects clearances I think.
