Author Topic: mk2 golf gti fuel pump removal problem please help  (Read 7903 times)
Offline davidcaig90
Re: mk2 golf gti fuel pump removal problem please help
« Reply #10 on: 15 February 2011, 11:00 »
SO fitted new fuel pump from a corrado kr today thanks for help that spray done  :smiley:the job
 BUT when fitted noticed the pump is a bit noisy is this somethin I should worry about I still have pump from my old 1 but just wondering is it an urgent issue as would rather leave it and buy a brand new 1 in a couple of months
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #11 on: 15 February 2011, 11:31 »
Offline davidcaig90
« Reply #12 on: 15 February 2011, 16:24 »
YEAH thanks I used similar stuff to get nuts off worked a treat but changed the whole housing and pump but the 1 I put on is quite loud compared to my old 1 which I still have still have should I change pumps or is the noise ok ?
« Reply #13 on: 16 February 2011, 10:24 »
loud pump could be its on its way out, or maybe the lifter pump has packed in. unplug the 2 pin connector to the main pump then turn the key 1 click, you should hear tyhe in tank pump prime. if not replace it.
if it is working then its prob worth swapping your old pump over at some point, but its a bit of a pain i9n the rear now that you've already done the job
Offline davidcaig90
« Reply #14 on: 16 February 2011, 14:08 »
YEah lift pump is defo working checked last night think pump Is on way out car kept cutting out this morning until it was warmed up so al try get it changed at weekend does any1 know the part number for the 3 screws that hold the pump in and where to get them from as my 3 are rusted will be a hard enuf job gettin them out never mind useing them again lol thanks
« Reply #15 on: 16 February 2011, 14:16 »
N   104 047 01 - screw - 0.34+VAT x3
N   902 628 02 - pump seal - 6.47+VAT
Offline davidcaig90
« Reply #16 on: 16 February 2011, 14:39 »
WHere is that from ? Vw thanks
« Reply #17 on: 16 February 2011, 14:50 »
ya vw
Offline davidcaig90
« Reply #18 on: 17 April 2011, 17:35 »
UPdate I bought a brand new pump and fitted runs better and no loud noise :D thanks for all the help
Offline Neo Badness
  • Feet are for pedals
« Reply #19 on: 17 April 2011, 18:04 »
How much were you for a brand new pump out of curiosity?
