Author Topic: Replacing driver's side track rod  (Read 1781 times)
Offline al_bey
« on: 13 February 2011, 19:05 »
Hi all,
I recently took my car to get the tracking as i knew it was out after lowering my car, the guys at the tracking place said the ends were seized so they couldnt adjust it. I took it home with the tracking still out and shredded a bit more rubber off my tyres.  :cry:
I have tried everything to get the track rod end off, but it is completely siezed. I have used an oxy acetylene torch until it is glowing red hot and still no luck. The 13mm spanner grip on the track rod has now rounded due to the amount of force i had to put on it. (I even clamped it with a vice and still no joy).
So basically now i'm just going to have to replace the whole track rod. I'd just like some advice on how easy it is to change. I can only jack the car up, dont have ramps of anything. Is it a job for the garage, or shall i do it myself?
Any advice appreciated.
Offline stupow
Re: Replacing driver's side track rod
« Reply #1 on: 13 February 2011, 21:07 »
just a long shot. have u tried turning it the other way? normally one side has a left hand thread.
Offline al_bey
« Reply #2 on: 13 February 2011, 21:49 »
It has turned slightly, so i know i'm doing it the right way, but now it won't budge at all.......
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 13 February 2011, 21:54 »
Have you tried a pair of stilsons on it after heating it?
Offline al_bey
« Reply #4 on: 13 February 2011, 23:20 »
Ive just looked what stilsons are, i have tried them on the track rod end but not on the actual track rod itself. I might have to give it a go, or take it to the garage, it would be a lot easier in a pit or on a ramp.......
« Last Edit: 13 February 2011, 23:22 by al_bey »
« Reply #5 on: 13 February 2011, 23:40 »
If you have heated it that much you would better to replace the complete rod.
« Reply #6 on: 13 February 2011, 23:56 »
Good point, all the heating may well have made the metal brittle and therefore weaker now anyway.
Offline cobalt6700
« Reply #7 on: 14 February 2011, 08:17 »
By heating to cherry red and allowing to cool naturally you have just annealed the track rod, plus any grease that was in the joints has boiled/burnt off.
New trackrod is the way to go  :smiley:
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline al_bey
« Reply #8 on: 14 February 2011, 10:51 »
That's what I'm going to do, I just wanted advice on how hard it was and if should do it myself or whether i should take it to a garage....
« Reply #9 on: 14 February 2011, 11:10 »
put it on full lock that side, peel the boot back and you'll see the spanner flats on the rod end. just a case of can you get a spanner on it! you may have to take the wishbone off but peeps have said they managed ok
