Author Topic: exhaust  (Read 1305 times)
Offline chubbs111
exhaust
« on: 12 February 2011, 17:04 »
i heard my exhaust blowing the other day     so today i got under car from drivers side  and about a foot back from the engine is a torpeedo shaped box and on the side of it was a hole that was proud of the box it looks like something should be in the hole anyone any ideas  the hole was about 6-10mm diameter
Offline snifferdog
Re: exhaust
« Reply #1 on: 12 February 2011, 17:06 »
Its not the hole for the lambda sensor is it? You got any loose wires knocking about?
Offline chubbs111
Re: exhaust
« Reply #2 on: 12 February 2011, 17:25 »
couldnt see any wires     its on an early 93 model gti    i couldnt see any threads in the hole either
Offline ashbreed
Re: exhaust
« Reply #3 on: 12 February 2011, 17:46 »
Was it towards the rear 1/4 of the cat? There's two places u can put the lamba sensor on the 92-93 cats 1 at the front n 1 at the back. Same thug happened to mine. Just get some1 to weld the hole up for ya. U find that the crap noise will go, there b more power n ur fuel economy will b much better!!
Offline Mike87Turbo
Re: exhaust
« Reply #4 on: 12 February 2011, 19:47 »
+1 especially if the hole is perfectly round and has threads on the inside of it. Either weld it up or try and find a plug that will fit it. Some garages carry these as ive used sump plugs in the past with the same thread on them.
Mike
Re: exhaust
« Reply #5 on: 12 February 2011, 20:56 »
Sump plug will or should fit, check you have a lambda sensor fitted 1st.
Offline Bellend
Re: exhaust
« Reply #6 on: 12 February 2011, 21:02 »
We had this on a cabby at work. Hole, deffo not for the lambda on the cat, no threads and causing a noise. Really strange.  :undecided:
Where all my moneys went.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: exhaust
« Reply #7 on: 13 February 2011, 10:12 »
drill and tap it out then stick a bolt in there if you haven't got access to a welding plant.
Offline chubbs111
Re: exhaust
« Reply #8 on: 13 February 2011, 14:20 »
looks like its already drilled so just need to tap it         thanks for your help yet again guys
