Author Topic: New oil pump jammed  (Read 956 times)
Offline e11ie
New oil pump jammed
« on: 12 February 2011, 14:45 »
Hey
My oil pump failed recently and so I replaced it with this....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250746458911&ssPageName=STRK:MEWNX:IT#ht_500wt_1156
My car is a 2l (AWG bottom end) with a 2E dizzy and PB head
On start up the oil pump jammed and sheared the pin on the dizzy leaving the bottom cog to fall off!
Out of the car the oil pump spins fine. I have had the locating sleeve which it sits in inside the engine out ( it was already loose) sanded that down, polished and re-installed but still no luck. Again though out of the car the oil pump spins freely within it.
It would seem as though I am missing a spacer but I have even put washers between the oil pump and engine face and it still jams even with the bolts only done up finger tight.
I have even tried jacking the car so it is perfectly level to see if tht would help me locate it better but it still jams.
I'm out of idea other than leave the bolts loose...which clearly is a retarded idea!!
Ellie  :smiley:
Re: New oil pump jammed
« Reply #1 on: 14 February 2011, 11:17 »
compare the 2 pumps side by side, see if there is any difference. topran usually good gear though
