Author Topic: mk3 2.0 8v poor acceleration  (Read 3236 times)
Offline golf8v
« on: 11 February 2011, 21:21 »
hi guys and girls, i have a mk3 gti 8v just lately it has no accerleration from 3/4 to full throttle it drives well had dont miss a beat just really flat can any one help plz
Offline Khare
  • The bear that khares
Re: mk3 2.0 8v poor acceleration
« Reply #1 on: 11 February 2011, 21:25 »
More details please.
What do you mean no acceleration from 3/4? Does it misfire, or what? Maybe the cable not opening the throttle body properly?
Offline golf8v
« Reply #2 on: 11 February 2011, 21:29 »
its moving full thottle ok, just car is holding back like theres no power
Offline dom
  • Back in a Mk4
« Reply #3 on: 11 February 2011, 21:30 »
I've said it before and i'll say it again, it's a Mk3 - deal with it :lipsrsealed:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 11 February 2011, 21:31 »
Yeah, could be a sticky accelerator cable or throttle body butterfly. Are the revs cutting off at any particular point ie. 5000rpm?
« Reply #5 on: 11 February 2011, 21:32 »
How long have you had this car, are you familiar with mk3 Golfs?
Offline golf8v
« Reply #6 on: 11 February 2011, 21:34 »
no just had loads of mk2 golfs, yes 5000 would be where it gets flat
« Reply #7 on: 11 February 2011, 21:36 »
Generally when a mk3 cuts off at 5000 rpm it means it has gone into 'safe mode', have you changed the timing belt or had the timing adjusted recently?
Offline golf8v
« Reply #8 on: 11 February 2011, 21:39 »
no nothing done, it was running sweet but decided to go flat on me
Offline Khare
« Reply #9 on: 11 February 2011, 21:42 »
To be fair, an 8v won't go much more after around there...
This is a standard engine graph
As you can see torque drops a lot, and after 5500rpm the HP falls too.
And now this is the same engine with a rally spec cacmshaft and some mods
Torque still drops a fair amount, but it holds peak HP for a little bit longer.
8v's don't really like to rev...
If the limiter kicks in at 5000rpm then yes, but if it revs above then no...
