Author Topic: Which injectors could (should) I use?  (Read 1337 times)
Offline Mr.Tom
« on: 11 February 2011, 07:45 »
I have seen a few people who are talking about getting different injectors installed. Was just wondering what difference it would make, and which ones I should be looking at if I wanted to.
Also, does anyone know of a good injector cleaning place round North Devon? Or a mail in service. Want to start cleaning up this engine a bit, and see if I can catch any of the lost horses :)
Re: Which injectors could (should) I use?
« Reply #1 on: 11 February 2011, 08:04 »
Little or no point unless you have done major mods.
Offline javalin
« Reply #2 on: 11 February 2011, 11:02 »
seems to be all web-based.  Planning to get mine cleaned and tested this year - http://www.injectorcleaning.co.uk/
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
  • The bear that khares
« Reply #3 on: 11 February 2011, 12:04 »
Blimey £70 to clean 4 injectors, excluding postage!  :shocked:
Offline javalin
« Reply #4 on: 11 February 2011, 12:07 »
what else would you do?  They must be at least £70 each to buy new, and scrappie will be in the same condition, etc.  Didn't think it was unreasonable personally.  Suspect one or more of mine is acting up a bit.
J
Offline Khare
« Reply #5 on: 11 February 2011, 12:11 »
J
Nothing else to do, just £70 for about 2 hours worth of work in total is quite expensive I think. I guess it's roughly what everyone charges for injector cleaning.
Offline vw-john
« Reply #6 on: 11 February 2011, 12:24 »
Offline javalin
« Reply #7 on: 11 February 2011, 12:24 »
true, but also we don't have the gear to do this at home.  Appologies if previous post came across as blunt/rude - not mean't to be!
pretty much I think.
J
« Reply #8 on: 11 February 2011, 12:40 »
You could also try your local Bosch agent.
