Author Topic: Fluctuating idle speed  (Read 2147 times)
Offline trizza
« on: 10 February 2011, 21:56 »
Can you help?  The idle on my my Mark v GTI DSG keeps going up to about 1300 then down to 800... Could this be a PCV issue? All help appreciated.
Offline Hurdy
Re: Fluctuating idle speed
« Reply #1 on: 10 February 2011, 23:52 »
Sounds like it could be either that or one of the coilpacks. :smiley:
Seat Leon Cupra Black 290 DSG
Offline sprout99
« Reply #2 on: 11 February 2011, 07:45 »
yes or coilpack
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline pluslyn
« Reply #3 on: 15 February 2011, 14:26 »
Just a thought.
Make sure that you have no inlet manifold  leaks, eg Air filter box, pipe work etc.
Also check Air Filter is seated correctly & Clean.
Offline Saint Steve
« Reply #4 on: 17 February 2011, 07:48 »
Could be a failing PVC, as it is a weak spot, and will cause erratic idle if faulty.
