General discussion
Steering wheel swap
Topic: Steering wheel swap (Read 1257 times)
laydon
Steering wheel swap
03 March 2005, 13:32 »
Hi I managed to pick up a brand new mk1 gti steering wheel would it be a direct swap for a late mk1 gti convertible steering wheel, I have checked on etka and the relevant part numbers appear to be the same.
AdamB
The Perfect Storm
Re: Steering wheel swap
03 March 2005, 15:36 »
a late mk1 cab has the same splines as the mk2. The mk1 tintop has a different sized spline from what I remember. So I dont think it will swap across without some sort of shim.
I don't own this anymore - I just can't be arsed to change the picture
...joe
Forum Supporter
Forum addict
03 March 2005, 18:18 »
Quote from: AdamB on 03 March 2005, 15:36
the early mk 2's had the same size spline as mk1's i think. they definately changed around the whole 90 spec time so its probable that they could be swapped. i guess the easiest way(other than taking your wheel off and measuring both) is to see what aftermarket boss kits fit both mk1 and mk1 cab.............
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
General discussion
Steering wheel swap
