Golf mk3
hardmonkeys
no fault codes but cutting out-boring, do not read
Topic: no fault codes but cutting out-boring, do not read (Read 1003 times)
stupow
09 February 2011, 19:33 »
i know this is well talked about and most people are probably bored of it but my 8 valve been misfiring then cutting out. cleared the codes that were showing and have been driving around but now not getting any codes. would of thought a problem would have shown up or is this not always the case?
Last Edit: 26 February 2011, 22:57 by stupow
Deano2711
1992 VR6
Re: no fault codes but cutting out
09 February 2011, 19:36 »
Fault codes don't always come up Mate. Try doing a search and you will find plenty of answers but try cleaning your Throttle Body first
stupow
09 February 2011, 19:38 »
ok mate ill have another read around. already cleaned out the throttle body with carb cleaner though. im thinking maybe coil
stupow
09 February 2011, 20:10 »
have also tried changing ecu relay but gsf gave me wrong one, there werent enough pins on the one they sold me
mark-mk3gti
09 February 2011, 20:36 »
It cutting out while driving? Especially when warm? For me it was the crank sensor! And no fault codes showed up.. When I took it out it fell apart in my hand, check my build thread and there is a pic of it...
stupow
09 February 2011, 20:41 »
mines the 2e engine, it hasnt got a crank sensor has it? its normally when hot but has done it straight from cold start a couple of times
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
10 February 2011, 09:21 »
yeah no crank sensor, id be looking at the dizzy and the wiring to it, plus the obvious like new leads, plugs, cap and arm from here:
http://www.vwspares.co.uk
stupow
Reply #7 on:
26 February 2011, 13:46 »
Drove it to the mechanic that used to look after my grale. after 5 mins he decided its the amplifier that is bonded to the coil. shame it cant be bought seperate :-(
Golf mk3
hardmonkeys
