Author Topic: Rivage cab INNER Anti roll bar brackets  (Read 7537 times)
Offline SoundillusioN
Re: Rivage cab INNER Anti roll bar brackets
« Reply #10 on: 09 February 2011, 19:06 »
Oh and FYI, once those nuts are off the whole lot should come off with it unless its rusted on.
Below you can see what they look like when removed.
You can also see that the stud that's sheered is like the bolt I posted, held in place by two spot welds.
« Last Edit: 09 February 2011, 20:48 by SoundillusioN »
Offline Guy
« Reply #11 on: 09 February 2011, 19:09 »
Ok so I did what I could to see what the crack is as all my carpets and soundproofing is still out.
Firstly, if you go down the nut and bolt trick to reuse the bracket then i'd use something like this, possibly get it welded on if you know someone..
There's no clearance between the bracket and the floor for a normal bolt.
Secondly, as far as being able to replace the two studs with bolts should they sheer, i'd say good luck with that.  Looks like they are welded in studs with no access unless you cut the floor.  Sadly these studs are in a place where the floor splits into 2 skins leading up to the bulkhead.  There is a grommit hole in the interior floor skin by the heater matrix area as the floor ramps up to the bulk head, I can clearly see the second skin.  :sad: My advice, soak the sh*t out of the nuts with WD overnight and be very gentle with them when trying to undo.
thanks shaun
so... its possible to access this area by lifting the carpet up?  thats easy enough...
hmmm... balls... just had a thought that I dynamatted the mk1 footwells :/
« Reply #12 on: 09 February 2011, 19:39 »
thanks shaun
No.... sorry mate. read it again.
Does that make sense?... there is nothing to see from inside the car.
Offline Guy
« Reply #13 on: 09 February 2011, 21:40 »
thanks shaun
yep... makes sense now... at least the dynamat is staying intact!!  :grin:
« Reply #14 on: 09 February 2011, 21:47 »
thanks shaun
Yep.... Just hope none of these sheer and Chuff ends up cutting your floor up to put bolts in!  :grin:
Offline Guy
« Reply #15 on: 09 February 2011, 21:57 »
thanks shaun
in short... lube it and gently does it!!  :grin:
« Reply #16 on: 09 February 2011, 22:01 »
You've got it... I had no end of stuff siezed on mine after being stood for so long... Anything I wanted to undo was always plastered in WD40 the day before.. touch wood, I haven't snapped anything yet...  Wait till I do some work on my ARBs...  :lipsrsealed: then i'll take back everything i've said!  :grin:
Offline Guy
« Reply #17 on: 09 February 2011, 22:15 »
chuff... you heard the man... lube it up big boy!   :grin:
« Reply #18 on: 09 February 2011, 22:34 »
Then carry on with the car.......  :lipsrsealed:  :grin:
Offline Guy
« Reply #19 on: 09 February 2011, 22:46 »
oooh matron!  :grin:
