Author Topic: help needed in west yorkshire with seats  (Read 1301 times)
Offline gazman1011
  • if your not first, your last!
« on: 09 February 2011, 09:58 »
hi all, i got a interia now for the mk2, but i cant fathem out how to change it over? im struggling, does anyone know how to take off the seats? i know i need some screws for the rear bench but wat size
thanks
Offline Agreeable Slick
  • Unit
Re: help needed in west yorkshire with seats
« Reply #1 on: 09 February 2011, 10:07 »
Front seats - remove bolt in the front arm of the chair where the arm is to slide it back and forth, remove plastic trims that run on the top of the runners (move chair as far forward as possible) then pull handle to slide the chair back, keep going and it will slide out of the runners at the back, angle it up slightly and the front runner will pop out too.
Rear seats - remove covers over screws at base of seats, unscrew all four bolts, pull tabs on tops of seats like you were trying to lay them flat, and they just lift out.
Easy peasy.
That'll be a fiver please. :smiley:
« Last Edit: 09 February 2011, 10:16 by Agreeable Slick »
Offline gazman1011
« Reply #2 on: 09 February 2011, 10:14 »
IOU £5 lol
thanks for that, ill get in with this now!
