The garage
oil evrywhere and gearbox whine
Topic: oil evrywhere and gearbox whine (Read 2349 times)
ryegault
09 February 2011, 00:20 »
hi folks, tonight i was giving my 99 1.8t gti a thrashing then noticed a smell of oil so pulled over, popped the bonnet and there was oil all around the passenger side of the engine and all over the top of the gearbox, then about 20 miles later i noticed the gearbox starting to whine in 1st 2nd and 3rd. but the oil apears to be coming from the block somewhere but cant pinpoint exactly where.
any ideas?!
cheeeeeers
danny_p
Forum addict
Re: oil evrywhere and gearbox whine
09 February 2011, 01:35 »
what it smells like will soon tell you if it's engine or gear oil
all the VW's have gone bar 1.
Agreeable Slick
Global Moderator
Serious forum addict
Unit
09 February 2011, 08:58 »
I would hazard a guess that the gearbox has leaked oil everywhere. Which I would also hazard a guess as driveshaft seals having given up the ghost.
As danny states though, what does the oil smell like?
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
ryegault
09 February 2011, 15:52 »
smells like hydraulic oil. cheers
Wayne
Sir Postalot
09 February 2011, 15:55 »
Sounds like gear oil then
ryegault
09 February 2011, 16:22 »
ok yes its defo gear oil then. is there any common places it leaks from? its mainly sitting on the top of the box. furthest away from the engine, under the gear linkage area.
danny_p
Forum addict
Reply #6 on:
09 February 2011, 21:03 »
Diff may have thrown a rivet and made a new drain hole, in the diffcaseing somewhere, if there are no holes on the ouside pop the clucth cover plate below the enigne and see if oil is in there. ether way if it has poped a rivet it's f**ked
ryegault
Reply #7 on:
09 February 2011, 21:30 »
is the clutch cover plate the black plastic rectangle with a handle? hope it aint too trashed!
danny_p
Forum addict
Reply #8 on:
10 February 2011, 00:36 »
metal cover at the bottom between engine and box the lower section removes, if thats all full of oil the clutch is f**ked as well
ryegault
Reply #9 on:
11 February 2011, 16:52 »
got it over a pit today and the oils leaking out the tell tale hole at the bottom of the bell housing
so looks like the gearbox will have to come out before further diagnosing! theres no clutch slip though so clutch may be salvageable
The garage
