Author Topic: mk3 gti 8v stearing problems  (Read 1958 times)
Offline carlton28
« on: 08 February 2011, 21:56 »
Hi i have a problem with my stearing, when i turn left or right there is a knocking and as of today when im driving in a straight line the stearing shakes rather badly. Can any one give me advice of what my problem is pls as i want to get it sorted soon rather than later.
Thanks.  :undecided:
Re: mk3 gti 8v stearing problems
« Reply #1 on: 08 February 2011, 23:31 »
Rack problem, air in the system or top mounts.
Offline carlton28
« Reply #2 on: 09 February 2011, 14:44 »
thanks for you comment, don't think it is mounts as i had them checked last week plus i had a new front engine mount put in as the other one broke...
will keep the air in the system in mind and the rack thanks again  :wink:
« Reply #3 on: 09 February 2011, 15:56 »
Check and see if the belt is slipping
Offline carlton28
« Reply #4 on: 10 February 2011, 14:33 »
i'm not that good under the bonnet lol, what belt am i looking for?
Offline Seanl
« Reply #5 on: 10 February 2011, 16:53 »
Just in front and to the left of the engine as your looking at it, you will see the alternator with a belt attatched. if you have a lood down below that, you will see a smaller and thinner belt. That is the power steering belt.
Offline carlton28
« Reply #6 on: 10 February 2011, 21:30 »
ok coolio thanks i'll take a butchers tomorrow   :grin:
Offline trackday
« Reply #7 on: 10 February 2011, 22:14 »
check your drive shafts buddy they start knocking on corners first then as they get really knackered and the bearings start to break up you get wobble noise and then no drive when they totally go.quick way to test handbrake on, put on full lock, grab the drive shaft and see if you can turn it forwards backwards if you can its knackered also check for up and down movement and in and out
Spec- Sounds awesome 2800CC VR6 200BHP Remapped with 7300 rev limit. Kent cams, cold air carbon intake kit. Forged pistons,power boost valve,6 branch manifold, de-cat pipe and full powerflow exhaust system.Grooved discs with red stuff pads. Gaz Gold fully adjustable suspension, 3.8 camber at front.
Full race cage, Momo steering wheel and corbeau race seats with four point harness. Fire extinguisher and 4.26 final drive conversion
Offline carlton28
« Reply #8 on: 11 February 2011, 19:26 »
ok coolio thanks, aslo my oil light is on and beep beep beeping how can i turn the nose of till i get it sorted??
Offline snifferdog
« Reply #9 on: 12 February 2011, 20:25 »
Put some oil in it. :grin: :grin: :lipsrsealed:
