Author Topic: golf 1.8 turbo engine  (Read 1300 times)
Offline lord14
« on: 08 February 2011, 21:55 »
got a 1.8t engine and i went out in it tonight , was running fine and floored it and went fine , slowiing down it started making a crazy knocking noise and then carried on from there , pulled up checled timing and it appeared to be fine , took spark plugs out and it isnt as loud but then put them back in and its really loud, still same amount of power and no miss firing , sounds like its coming from the bottom of the engine near the bell housing ,
Offline tech1889
  • Mk2 GTI FTW !!
Re: golf 1.8 turbo engine
« Reply #1 on: 08 February 2011, 22:15 »
engine code ?? scanned it for faults ?? coil pack ??
Offline lord14
« Reply #2 on: 08 February 2011, 22:19 »
agu , no still runs fine , just making a really bad knocking not sure if its the botttom end or gearbox but would the gearbox make a noise even if im jsut turning it over on axel stands with it in neutral
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 08 February 2011, 22:22 »
Ok well it pains me to say this but it wont be coil pack then lol..
My first look would be the gear box mount.. they can break but also the rubber insert breaks down and causes knocking
Offline lord14
« Reply #4 on: 08 February 2011, 22:27 »
checked the mounts mate , nothinks up my guesses are either the clutch or gearbox has broken , or a bottom end knocking but it sounds like its coming from the bell housing
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 08 February 2011, 22:28 »
Seriously even if the mount looks ok doesnt mean it is mine looked fine and removed to poly bush it and it was well on its way not knocking but on its way.. does the knocking get louder as the revs climb ?
Offline lord14
« Reply #6 on: 08 February 2011, 22:30 »
nope , i took the coil packs out and the spark plugs then it isnt as loud , but just running it i think it stays the same
« Reply #7 on: 08 February 2011, 23:13 »
Post a video if you can, that will help.
