Author Topic: ref exhaust  (Read 1261 times)
Offline chubbs111
ref exhaust
« on: 08 February 2011, 16:23 »
hi chaps    will the back box off a vr6  fit a 93 gti
Re: ref exhaust
« Reply #1 on: 08 February 2011, 16:29 »
if its an 8v no, if a 16v yes
Offline chubbs111
Re: ref exhaust
« Reply #2 on: 08 February 2011, 17:09 »
why will it not fit an 8v    is it the shape or the size of the connecting pipe
Offline dom
  • Back in a Mk4
Re: ref exhaust
« Reply #3 on: 08 February 2011, 17:31 »
The bore of the VR6/16v pipe is 55mm, 8v is 50mm.
Offline boneybradley
  • Back in a Mk3...
Re: ref exhaust
« Reply #4 on: 08 February 2011, 17:37 »
but you can replace the downpipe/middle box with the 16v/vr one
Offline chubbs111
Re: ref exhaust
« Reply #5 on: 08 February 2011, 18:15 »
sorry to be a pain   but will the front and rear springs fit a gti    im asking because a mate at work is breaking a vr6 and he has offered me the bits
Re: ref exhaust
« Reply #6 on: 08 February 2011, 20:59 »
Nope they will not on a 8v due to the difference in engine weight, rears may be ok.
Exhaust will fit with a sleeve
  • Back in a Mk3...
Re: ref exhaust
« Reply #7 on: 08 February 2011, 21:04 »
are they o.e or lowered springs? If lowered it's hit and miss if there correct rates etc (many sell just 1 set for all models!)
Re: ref exhaust
« Reply #8 on: 09 February 2011, 10:10 »
16v/vr6 exhaust will fit to the 8v cat, downpipe is pretty much the same on 8v/16v and the cat output diameter is the same 55mm diameter for 8v,16v and vr6. the 8v front pipe is 55mm at the front, then it nartrows down to 50mm at the back. 16v/vr6 is 55mm all the way back
however, i think there is a difference in cat length depending on the age of the car, this issue seems to crop up now & again but I cant say exactly what age the change happened.  all i know is my miltek mk3 cat bypass was shorter than another make one my mate bought, but the miltek one came with a short length of pipe to make up the difference
