Author Topic: Super unleaded  (Read 2625 times)
Offline skinny2468
Super unleaded
« on: 31 August 2003, 11:41 »
Hi.
Does anyone know what the timing of my 1996 Mk3 golf Gti 8v needs to be adjusted from/to so I can benifit from Super Unleaded 97 ron unleaded?
Cheers.
golfvr6
Re:Super unleaded
« Reply #1 on: 31 August 2003, 18:37 »
You do not need to adjust the timing to use super, you only need to retard the timing for 95Ron normal unleaded. However timing problems only happen with older mechanical fuel injection systems, not on yours as this fully electronic system. You cannot make adjustments on your system even if you wanted to. So you are ok to use normal unleaded or super. You will benefit from using super by doing nothing at all!
« Last Edit: 31 August 2003, 18:37 by golfvr6 »
Offline skinny2468
Re:Super unleaded
« Reply #2 on: 07 September 2003, 20:41 »
Thanks a lot for the info. I shall certainly give it a try next time I fill up.
Offline gtidean
Re:Super unleaded
« Reply #3 on: 15 September 2003, 17:43 »
Did you notice much difference with the super unleaded mate ?
golfvr6
Re:Super unleaded
« Reply #4 on: 16 September 2003, 00:01 »
Golfs in general usually run much better on Super.
Offline skinny2468
Re:Super unleaded
« Reply #5 on: 03 October 2003, 17:27 »
Nope   :'(
Hardly noticed any difference at all (except in the wallet).
Oh well....thanks anyway
