Author Topic: Argent help needed  (Read 1583 times)
Offline ian007miles
Argent help needed
« on: 07 February 2011, 18:18 »
While I was fitting my catch can I took the L shaped breather pipe out of the top of the oil filter housing and wen I looked at it there was a bit missing off of the bottom it had broken off and dropped in to the oil filter housing and I've just tryed getting it out but I've knocked it down the little hole in the block will this be ok. The bit of plastic is not that big it's about an inch long and a couple of millimetres wide and it's very britel it was bracking up as I was trying to get it out.
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline tech1889
  • Mk2 GTI FTW !!
Re: Argent help needed
« Reply #1 on: 07 February 2011, 18:20 »
not good news.. they are very brittle.. you cant leave it in the block god knows what would happen..
Offline ian007miles
« Reply #2 on: 07 February 2011, 18:30 »
How can i get it out Were does the little hole go
Offline ian007miles
« Reply #3 on: 07 February 2011, 18:56 »
Offline daz veedub
  • Operation 1.8t bolf
« Reply #4 on: 07 February 2011, 19:16 »
possible drop down in 2 sump
Offline ian007miles
« Reply #5 on: 07 February 2011, 19:27 »
Is that were the little hole goes Were does the oil pick up go
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 07 February 2011, 20:08 »
pick up is in sump
