Author Topic: Seat wiring  (Read 1347 times)
Offline ggoodwin
Seat wiring
« on: 07 February 2011, 18:15 »
I'm in the process of fitting some electric UV Recaros to my Mk2.  I think that they may have come from a Corrado originaly as they have two motors and heated seats.  The motors I am connecting up to Y/1 on the fuse box with a 20A inline fuse but I was told that the heated seats should be connected to D/9.  D/9 is already connected to something and it doesn't look like a particularly substantial cable so I was wondering if there was any reason why the heated seats couldn't also be connected to Y/1 with a 10A fuse?
The original heated pads have been replaced with a simpler affair which just turn on and off and are controlled by a thermal cut-out.  I was going to switch those individually using two HRW switches turned upside down as that looks the part :) .
Any thoughts/suggestions would be gratefully received.
Graham
Re: Seat wiring
« Reply #1 on: 08 February 2011, 10:19 »
on mk3/corrado there are like jumper blocks for various wires on the D plug so you can plug loads o stuff in.  you dont really want to plug em into the Y socket cos that would mean they are always live.
if it was me id pinch a D plug out of a mk3 golf in the scrappy along with all the jumper blocks, then splice this in. you could just splice the heated seat wire into D3, D/5, D/9 or D/11 though ;)
Offline ggoodwin
Re: Seat wiring
« Reply #2 on: 08 February 2011, 11:56 »
Thanks for the info and a very good point!  Don't want to be leaving the seats on overnight  :embarassed: .
Graham
Offline logeyboy
Re: Seat wiring
« Reply #3 on: 08 February 2011, 15:09 »
Sell them to me for £50 to save yourself the hassle...  :wink:
Offline ggoodwin
Re: Seat wiring
« Reply #4 on: 08 February 2011, 17:21 »
Damn, too late.  They're fitted now so I guess I'll just have to put up with them.  Thanks for the offer though :) .
