Author Topic: gear linkage bushes question  (Read 2386 times)
Offline mr mk2
« on: 07 February 2011, 11:32 »
right at this moment im changing my gear linkage bushes but i have a question in the diagram it shows a big red ball but mines a small oval shaped thing with groves in it does this mean mine has fell apart?
Offline sprout99
Re: gear linkage bushes question
« Reply #1 on: 07 February 2011, 11:46 »
it should be a splined ball covered in a rubber type stuff
see here  http://www.vwspares.co.uk/product_info.php?products_id=1388
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline mr mk2
« Reply #2 on: 07 February 2011, 11:47 »
picture of mine if this helps
Offline sprout99
« Reply #3 on: 07 February 2011, 13:11 »
yours is sha66ed - missing the rubber ball. Your forward and back movement of gearstick must be sloppy as fcuk
i had this on my last mk2 - new bit makes a big difference
Oak green mk2
V50 D5 Sportwagon
Offline mr mk2
« Reply #4 on: 07 February 2011, 13:22 »
cheers bud, i knew it dint look right but didnt know what it was
Offline mr mk2
« Reply #5 on: 07 February 2011, 13:47 »
Offline jackytwoshoes
« Reply #6 on: 07 February 2011, 14:54 »
If that part is the as the one from GSF then you need to file the top of it a bit to get it to fit the arm.
Offline mr mk2
« Reply #7 on: 07 February 2011, 18:25 »
all sorted and fitted now and WOW does it make a differance feels proper nice now
Offline sprout99
« Reply #8 on: 08 February 2011, 07:33 »
i changed the other 2 selector rods with white ends and a weighted mk3 shift rod - lovely now.
Oak green mk2
V50 D5 Sportwagon
Offline mr mk2
« Reply #9 on: 09 February 2011, 10:14 »
yeh i put a weighted shift rod on at the same time and it feel proper nice  :smiley:, i did 4get to do the pinch bolt up FT and got stuck in 3rd tho  :laugh:
