Author Topic: stem seals,How much to change????  (Read 5427 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 06 February 2011, 23:37 »
I have a mk2 and the stem seals have gone on it.Im getting married soon so money is tight and i have a choice of to either just sell it as is or repair it.
How much does it cost and whats involved??
Its only an 8v
Offline jmsheahan
Re: stem seals,How much to change????
« Reply #1 on: 07 February 2011, 08:04 »
Was a couple of years ago now but it cost me £180 to have them replaced on my 8v. They didn't have to remove the head.
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
« Reply #2 on: 07 February 2011, 16:15 »
if you can get the tool to remove the vavles do it your selve mate its easy
.....the project.........
Offline jocarl11
Offline emery1990
« Reply #4 on: 07 February 2011, 17:59 »
Are these normally the first things to go on an engine?
Offline tshirt2k
  • Been there...Done that...
« Reply #5 on: 07 February 2011, 22:26 »
Don't think there's much point just doing valve stem seals. They probably got knocked out due to loose valve guides. It's probably worth waiting and getting the exhaust valve guides done at least.especially with high mileage. My engine had loose exhaust valve guides at 123k when it was rebuilt.
 Usually about £15 a guide. you can lap in the valves, decoke etc. Put the stems in yourself with a deep 10mm socket. You may get some power back also.
« Last Edit: 07 February 2011, 22:28 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline danny_p
« Reply #6 on: 08 February 2011, 00:20 »
belive it or not vw are cheeper for guides than GSF well for the ABF anyway
all the VW's have gone bar 1.
Offline Sam
  • Sam I am
« Reply #7 on: 08 February 2011, 00:21 »
I believe that. VW are cheaper for very very odd things that you would think cost a bomb
Offline Ben Lessani
« Reply #8 on: 08 February 2011, 00:31 »
I disagree, I completely stopped any oil burning after replacing the seals with genuine VAG seals.
If you're a total beginner, I probably wouldn't recommend it. If you've removed the timing belt/camshaft before - then its a doddle.
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg902396#msg902396
Offline tshirt2k
« Reply #9 on: 08 February 2011, 21:46 »
Course new seals will stop oil burning. Just depends how long they'll last. What's the point of doing half a job? Especially as the heads off anyway.
