Author Topic: MK3 GTI STEREO PROBLEM  (Read 1190 times)
Offline Antquinn
« on: 06 February 2011, 18:42 »
Hi
I have a MK3 GTI and its has a ( dont Laugh ) Mutant CD headunit fitted.
The problem is when I turn the ingition off it looses all presets , tone controls etc.
One thing I have found out is that the car is using the original headunit connectors that came in the car from new,
so is the problem I have due to these leads?
Would I be better off going to Halfords and buying and after market set of iso ( i think they are called ) leads?
Ant
Offline Khare
  • The bear that khares
Re: MK3 GTI STEREO PROBLEM
« Reply #1 on: 06 February 2011, 18:45 »
You need to switch the permanent live and the ignition live wires. It'll be on the ignition live wires now hence why you're loosing all the preset stuff.
I think perm live is red, and ignition live is yellow.
Offline Antquinn
« Reply #2 on: 06 February 2011, 18:48 »
So would I just cut and rejoin them ?
Or get the extra leads and then cut and rejoin?
cheers
ant
« Reply #3 on: 06 February 2011, 18:55 »
As Khare said you need to switch the wires around.
Offline harlemex
« Reply #4 on: 06 February 2011, 19:15 »
+1 they pull apart
Offline Antquinn
« Reply #5 on: 06 February 2011, 19:28 »
they pull apart?
They are covered in almalgemating tape but seem to be hard wired, no obvious joins in the cable
cheers
ant
Offline harlemex
« Reply #6 on: 06 February 2011, 19:45 »
somebody must have butchered the wiring at some point. It will have to be cut and join after all.
Offline Antquinn
« Reply #7 on: 06 February 2011, 19:48 »
ok cool cheers guys !
cheers
ant
