Author Topic: 998 vag 153 alarm /imobiliser problem  (Read 1023 times)
Offline palmer
« on: 06 February 2011, 16:47 »
have an old  convertable with a faulty    "   black box   "
how do I   go about   " bye passing it  "   so I  can get the car to run  !!!
Have heard that  there are specific wires to cut  and  do something with  that will  let the car start  but  do away with the  " alarm / imobiliser "  bit
currently  the  flashers will not stop  and  there is  therefore no spark or working petrol pump
cheers
Rob
Offline mark-mk3gti
Re: 998 vag 153 alarm /imobiliser problem
« Reply #1 on: 06 February 2011, 20:01 »
hi mate,
as far as i am aware you cant just chop the immob out,   you will need the ecu defeating so it doesnt require the immob, or easier would be put another immob box in, (as long as you have the corresponding chips for keys) and configure it with vagcom.. ive just changed mine, rubjohnny helped me alot with the process, it only takes 30secs to code.. :)  maybe  someone else will confirm my comment.. :)
Offline palmer
« Reply #2 on: 06 February 2011, 20:53 »
thanks
I dont think my  " one key  "   is chipped
so may be  I just get another immobiliser fitted
cheers
Rob
Offline mark-mk3gti
« Reply #3 on: 06 February 2011, 21:45 »
if its a standard immob, im pretty sure the key should have a chip in it, but i could be wrong, what year is ur car?
Offline palmer
« Reply #4 on: 07 February 2011, 10:12 »
its a   P   reg   so  is getting on
i am pretty sure  the key is not  chipped
thanks
rob
